What is the difference between a 79 and 80 head? (Carb vs FI)
argonaut
Post by argonaut »
I have a head from a 1979 2L motor. I understand this was the only year the 2L had a carburetor. I am wondering if the 80-85 2L FI heads are any better than this one, or that much better to justify trying to find and buy one.
Does anyone know what the differences are between a 79 and 80-85 head or combustion chambers?
Thanks!
Jason M.
1964 Chevy K20 Suburban
1966 Chevy K20 Pickup
1981 Fiat Spider 2000
1996 Ford Bronco Supercharged
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
vandor
Re: What is the difference between a 79 and 80 head? (Carb vs FI)
Post by vandor »
Carb head has passages for EGR and air injection.
80spiddy
Your car is a: 1980 spider 2000
Post by 80spiddy »
Early 1980 had a carb also. Mine did.
BammBamm
Your car is a: 1982 Pininfarina Spider
Post by BammBamm »
The difference ia huge. The 79 and 80 carberated had Egr ports on both the intake and exhaust. The most desirable heads for a 2l is the 1800 head and the 2l fi head. The 1800 will give you higher compression and more hp. Both the fi head and 1800 head are compatible with both fi and carberated intakes.
Bill Woodbury
Design Engineer
Zero Shock Seating
1982 Spider 2000
argonaut
Post by argonaut »
Thanks for the replies so far, folks!
I think I have a handle on the 1.8l head. I have one of those also.
I am going to go out to the garage and have a look at those ports. So far I have seen that my 2L head has two ports on top, between the intake and exhaust towers. I also notice the cross-flow tube connecting from the Exh side to the Int side.
Jason M.
2005 Honda RC51
1981 Honda CB750C
vandor
Post by vandor »
Well, yes, but the difference is only visual, I don't think the ports or combustion chambers are any different.
The 1800 head raises the compression ratio of the 2 liter slightly, but it's only a small difference, so it's only worth doing if the head needs to come off anyways.
bradartigue
Post by bradartigue »
vandor wrote:> The difference ia huge. The 79 and 80 carberated had Egr ports on both the intake and exhaust.
2000 carb heads have a different shape for the #1 chamber IIRC. But really the problems aren't so much the combustion chambers but the EGR ports and reed valve ports that all need to be blocked off. It just ends up being kind of an ugly head with the four bolts in the top and the home-made blocks for the EGR porting.
argonaut
Post by argonaut »
Alright, thanks guys.
I'm going to avoid using this 2L Carb head. I'll either use the 1.8L or find a 2L FI head.
Jason M.
2005 Honda RC51
1981 Honda CB750C
bradartigue
argonaut wrote:Alright, thanks guys.
Good move.
