idler reservoir
80spiddy
Your car is a: 1980 spider 2000
idler reservoir
Post by 80spiddy »
I decided to check the fluid level in my idler reservoir. I took the top off and there is some fluid there as well as dark film of light sludge. I then wanted to take the next portion off and it just turns a bit. It's loose , but wouldn't just pull off. This is on a 1980 and says Wayass-auto on the cover. Maybe it's original. Does this in fact just pull off and the next reservoir to fill is below that?
TX82FIAT
Re: idler reservoir
Post by TX82FIAT »
The main reservoir is under the cap. It is a two chamber system where fluid moves from one camber to the other. Think of a circle with a metal bar dividing the chamber that rotates. I holds something like three ounces of oil.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
80spiddy
Re: idler reservoir
Post by 80spiddy »
When you say cap, I think of the first piece I pulled off that had the bolts holding it together. But, you may be referring the next level down from there I assume. That just pulls off (it has the check balls in it)? Maybe there is a seal that is causing resistance to pull off even though it rotates.
fiatfactory
Your car is a: 1970 128
Re: idler reservoir
Post by fiatfactory »
4uall
Re: idler reservoir
Post by 4uall »
80spiddy
Re: idler reservoir
Post by 80spiddy »
Thank you. Twisted and pulled and it finally pulled off. Full of oil. Back together.
Fi8spider
Re: idler reservoir
Post by Fi8spider »
You may find this interesting, a write up I did of the way I overhaul idler arms.
http://t124.com/forum/viewtopic.php?f=3&t=11281#p135814
I'll be updating the details in that thread to include the seal sizes that kmoses used.
