Differential rebuild -- holding the pinion still
grrrdot
Your car is a: 1967 124
Post by grrrdot »
I'm rebuilding a torque tube differential, it's more or less the same as the pumpkin style diff.
To re-assemble I need to tighten the pinion nut to crush the sleve and set the pinion rolling torque. So, with the diff out of the car how do I keep the pinion from moving when I torque the pinion nut to crush the crush sleeve?
-G
njoconnor
Re: Differential rebuild -- holding the pinion still
Post by njoconnor »
If you still have the brake discs on the axles, you could try what I did: padded quik clamps on each side's brake disc, snugged up against the brake shields. Held it nice and tight while I torqued it down....
Neil
Neil O'Connor
Madison, WI
72 FIAT 124 Spider
ex-71 FIAT 124 Coupe
