Glove Box Question
- Your car is a: 1985 Spider
Glove Box Question
I messed with the latch on the glove box and now it will not open. It seems like the latch is locked, even though it is not. Any ideas on how to access the glove box?
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
1985 Pininfarina
2011 Eos
Re: Glove Box Question
Does the knob turn, or not?
Often the dash sags over the glovebox and makes it hard to get the latch to close or open. You may try applying upward pressure on the dash just above the glovebox lock and see if that helps.
The knob rotates about 90 degrees, which I think is about normal. It seems to rotate the same amount whether it is locked or not. I can't remember if that is normal. Could the "tongue" on the inside not be rotating? I took the latch off the glovebox door and maybe I did not put it back together correctly?vandor wrote:Does the knob turn, or not?
Don Avery
1985 Pininfarina
2011 Eos
1985 Pininfarina
2011 Eos
It should rotate 90 degrees to open, but IIRC it should not rotate when locked.
I think most likely it is not put together correctly and the latch is not rotating. Lifting the dash may free it, I'm not sure, but it's worth a try.
Tried lifting the dash, no luck. So no other secrets for getting into the glove box, huh?vandor wrote:It should rotate 90 degrees to open, but IIRC it should not rotate when locked.
Don Avery
1985 Pininfarina
2011 Eos
1985 Pininfarina
2011 Eos
- bradartigue
The dash is worth more than a glove box latch/lock, so worst case you just drill the bastard out.
On my buddy's 79 this happened and the lock had over-rotated. It took a bit of force on the knob but was able to turn it over and then it engaged. Oddly the same thing happened to his trunk lock.
1970 124 Spider
http://www.artigue.com/fiat
- Patron 2024
I have had luck pulling up on the dash while pulling down and back on the glove box door knob. I had the key in the lock so i had more of a grip. Probably just lucky but have forced a couple open this way.
I have worked on it for most of the morning with no luck. So would it be better to drill out the latch or cut the bottom of the glove box and reach up inside to unscrew the latch tongue? Can a new latch be keyed for my old trunk/glovebox key? I looked around the usual websites and Vick has the latch for $92. Ouch! Of course, I really don't care if it can lock or not - so maybe an aftermarket latch would work?
On another note, the whole point of getting the glove box open is that I need to remove the plastic piece around the shifter. To do that I need to remove the radio, to do that I need to remove the upper center console and to do that (I think) I need access to the glove box.
Don Avery
1985 Pininfarina
2011 Eos
1985 Pininfarina
2011 Eos
- Patron 2024
Just noticed your car is an 85. Your dash is pretty unique compared to my 81. I am not sure your latch would work the same as mine. I find it counter intuitive rotating the latch counter clockwise to release for opening the glove box door. I am not sure which way I turn the key to unlock as I never bother to lock mine. I am pretty sure I turn the knob counter clockwise to open.
Does anyone know if the 85 glove box door is the same as say an 81??? There should be lots of used doors kicking around if that is the case. I might consider cutting door over drilling the lock as replacing the lock means a separate key for the glove box from the trunk and doors.
If you don't car if it locks or not then you could get a used one for very little moeny. I think the glovebox door is the same color on the Fiat and Pinin Spider 2000s, someone correct me if I'm wrong. The lock/latch is the same on all Spiders.
- Patron 2019
I replied to your other post, with a possible solution to pursue.http://www.fiatspider.com/f15/viewtopic ... 19&t=32103
Current 81 Spider 2000
Previous 76 Spider
Previous 76 Spider
I had this problem as well. Once I got it open I put a light and my phone on video record to see what was going on. It was a saggy dash issue. When I fully turned the knobs the tongue was jamming against the top of the latch. I ended up filing down the tongue and that worked for some time. Now I an thinking about other options like removing the catch and putting a magnet catch in place.
Good luck.
Good luck.
