timing : intake cam sprocket alignment
philoutch
Post by philoutch »
Hi guys,
Just started looking at the timing belt replacement, I think I got it but the only problem I have for now is to align intake cam sprocket perfectly with the mark. Turning the cam always bring me to that same position, not possible to really point it to the mark, is that OK ?
for what ever reason the picture is upside down, Sorry !
THX
divace73
Re: timing : intake cam sprocket alignment
Post by divace73 »
try to align it when you are putting the belt on to lock it in place.
Also is that cam wheel a metal unit of the plastic type? if it is the later the normal recommendation is to swap it for a metal unit as they wear with usage (even though they are much much lighter, I can only image they were designed to be replaced with the timing belt)
Cheers David
see my >>You tube channel<<
philoutch
Post by philoutch »
plastic type, yes ! I am going to change it then ;)
Thank you !
philoutch
Post by philoutch »
I have a 1800 CS1 US, are they all the same pulleys ? can I buy these ?
http://www.ebay.com/itm/Pr-Fiat-124-Spi ... Jf&vxp=mtr
Thank you !
djape1977
Post by djape1977 »
yes, those will work
philoutch
Post by philoutch »
ALL Fiat 124 pulleys will fit ?
djape1977
Post by djape1977 »
all fiat DOHC engine pulleys will fit
124, 125, 131, 132...
OHV 124 and 131 not
