Page 1 of 1
Rust inside of shock towers..please look at pics and video
Posted: Sun Nov 01, 2015 8:34 pm
by Frankd1
I was poking around my engine bay and looked through the ports to see the inside of the shock towers. I noticed the rust on the inside layer of metal. It is rotting away in parts.
From what I can tell it has not perforated through to the outside of the shock tower. From the wheel well area the towers look intact. They do have a coating on them but from what I can tell there does not seem to be any rust though the shock tower.
The area that is rusted from the inside looks like a thin skin with solid metal behind...
the first two videos are of the lower area where the shock absorber passes through, the next three are of the upper area.
This is the passenger side..
https://www.youtube.com/watch?v=RhiPAKdYie8
https://www.youtube.com/watch?v=RixIjtDG200
https://www.youtube.com/watch?v=zazr4k16Pf8
https://www.youtube.com/watch?v=B3x3BD7zu_o
https://www.youtube.com/watch?v=G6Y2q76oC-M
Re: Rust inside of shock towers..please look at pics and video
Posted: Sun Nov 01, 2015 8:55 pm
by Frankd1
Posted: Sun Nov 01, 2015 9:27 pm
by Frankd1
Feeling around the rust areas it seems like several layers have bubbled up....almost like layers of an onion skin, but not rusted through to the outside..
I fear the worst though in that I will need to have the shock towers replaced....
Posted: Tue Nov 03, 2015 10:38 pm
by 76124
Frank,
I am in a similar boat though I must admit yours looks a bit worse off than mine. If I am not mistaken that rust inside the shock access opening is living in the heavier shock tower metal and something you want to address promptly. Maybe someone who has pulled these apart can weigh in more on that.
My drivers side has rust in the "pockets" on the outer layer, where the water and dirt pool, but and do not appear to be penetrating the inner layer, the heavier more structural element. In this case I am going to remove the outer skins and see what is really underneath. If it's not too bad I will grind the rust down and remove as much as I can. I may try to pour POR15 in any seams to keep further rust at bay. Then patch the holes in the outer skin and weld it back on. I know the outer skins are available but there are so many spot welds holding these on it might be easier to remove the entier tower than these outer skins. The passenger side is not so nice and I think i will just replace the entire tower with the version Casaba sells for $269. Finding good used examples is proving to be too time consuming. I would still have to remove them and clean them up from a downer car
My only question is getting the new one in the same place as the old. My plan is to etch around the old using a engraving tool so the lines are not removed during cleanup of the area. I will also measure from the front to the leading edge of the tower assembly in several locations and then again from the bottom of the spring seat to the floor, when the frame is sitting at a predetermined height from the floor. Floor slopes out so the car will need to be sure to be in the same location.
I have the advantage of having the engine out, so removing the many spot welds from inside will be a bit easier.
If your not up to this task, I can't even imagine the cost of all this labor at a body shop.
Rust never stops, so if your going to keep the car, I would invest in getting it repaired as soon as possible. Why add an accident or additional damage to the car to the overall repair bill. IMO.
Posted: Wed Nov 04, 2015 12:21 pm
by Frankd1
Thanks for the reply!
I'm going to clean up as best I can on the inside..
Once I get the front end up on jack stands I will clean away all of the black coating in the wheel well area to expose the shock tower metal and assess from there.
I'm thinking replacements will be required..
I can see all of the pinch welds in the engine bay where the towers are connected. Do these get ground away or can you drill the pinch welds out?
Do you have any photos of what you are dealing with on your car?
Thanks again
Posted: Wed Nov 04, 2015 3:06 pm
by 76124
This is what my passenger side looks like...the hole behind the upper bump stop has been there for a decade or more, so not progressing much in the cars softer life of summer driving. Unfortunately rust never sleeps and progressed outwards.
Passengers side by
Fiat Parts, on Flickr
Passengers side by
No surprise these creases only aided in the eventual rot by holding the water and debris for years.
Passage side by
I was able to make some progress on the driver side earlier today but stopped as I am not able to access the spot welds on the back side closes to the firewall without an angle drill. Might be cheaper to just remove the entire shock tower and know all the rust is gone and not have to patch and weld all the rusted areas. Like most I have less time than I would like, so what works fastest is usually the better solution.
There are just a few spot welds -
2015-11-04_11-20-09 by
Without the bump stop...you can see the same hole forming here as is already there on the passenger side -
2015-11-04_11-20-26 by
2015-11-04_11-20-42 by
Very little force needed to push this punch through..not very promising -
2015-11-04_11-20-56 by
From inside the hole the punch went through appears rock solid on the surface -
2015-11-04_11-21-11 by
Decent right angle drill will cost me about $200, almost the cost of the new shock tower.
I am not sure rust in this upper are is as bad as if it were in the lower areas where the shock actually mounts, but to me without this area being sound it could collapse after a stout pot hole and the upper control arm would roll up under the fender...catastrophic to say the least.
Biting the bullet and ordering two complete shock towers seems like the direction of least resistance at this point, though my wallet disagrees.
Posted: Wed Nov 04, 2015 5:42 pm
by Frankd1
Thanks for posting those photos, I'll know more once I get the car set up for winter storage.
I will be able to get to the outside of the towers in the wheel well at that point.
Are you drilling out those spot welds or angle grinding them away?
Posted: Wed Nov 04, 2015 6:27 pm
by 76124
I'm using a spot weld remover from Blair. The metal is so soft it works very well. Only issue is the welds are often not round but more oblong, but you get enough the pop them off. It's about $60 for the kit with 4 cutting g heads. I think I will start a thread on the cimplementation towe R&R. I could find little complete info on the job. Does that mean most abandon it or take it to the local body shop???
Posted: Wed Nov 04, 2015 6:52 pm
by Frankd1
I'll look into that tool..
I wonder what most people do? I think if you have welding skills and are careful in the prep and alignment you can do it yourself.
I would imagine having the outline of the old tower would greatly assist in lining up the new tower..
Maybe some sheet metal screws to hold the new tower in place as you get things lined up and then add the spot welds from there
Posted: Sat Nov 28, 2015 9:39 pm
by jlw35
76124, were you able to remove the spot welds by working only from the wheel well as opposed to inside the engine bay?
Jeff
Posted: Wed Feb 10, 2016 12:48 am
by SLOSpider
Finally found my old thread about the shock tower repair on my 75 if your interested:
http://www.fiatspider.com/f15/viewtopic.php?f=14&t=9420
Posted: Wed Feb 10, 2016 8:10 pm
by Frankd1
Thanks for the link!
Posted: Mon May 23, 2016 11:44 pm
by mohle
