crossmember to frame bolt spinning!!!
I swear I searched for the answer but I can't find it. I need to remove my cross member and sure enough one of the four vertical bolts that are supposed to be held y a box inside the frame spins so I cannot get the nut off! What do I do now? If I cut it how do I re-attach the cross member? I've tried prying between the member and the frame rail to "hold" the bolt but it just spins.
Jeff Klein, Aiken, SC
1989 Spider, sold
2008 Mercedes SL65
2008 S600 Mercedes V12
1989 Spider, sold
2008 Mercedes SL65
- FiatMac
Re: crossmember to frame bolt spinning!!!
Try this thread. Search used was "crossmember repair".
http://www.fiatspider.com/f15/viewtopic ... ir#p186808
Stan McConnell
Retired Mechanical Engineer
Salisbury, North Carolina
82 2000 Spider (driving)
83 parts car
83 parts car
You could cut a slot in the end of the stud with a dremel tool, so you can keep it from spinning with a flat blade screwdriver.
I like the slot idea, I'll try that in the morning. Figure either way I'll be boring a hole up top to put a new bolt back.
1989 Spider, sold
2008 Mercedes SL65
1989 Spider, sold
2008 Mercedes SL65
You will find good photos showing crossmember to frame bolt repair here on page 5 & 7.
http://s253.photobucket.com/user/jonesb ... 220&page=1
- JEEPER
- Your car is a: 1979 SPIDER
If you end up cutting the bolt off you could use a NUTSERT which will give you a captive nut inside the frame. I have sone that require a 1/2" hole in the frame. I'm travling but, I think the bolt that the NUTSERT takes is a 5/16x18 but I'm not sure. If you GOOGLE NUTSERT and you think that will work PM me and I'll send you a couple. I needed them for my JEEP side steps so I bought 100 and used 8 and sold a bunch on the JEEP FORUM.[img]
