84 Azzurro Pininfarina
vdesigner99
Your car is a: 1984 Pinanfarina spyder
Contact:
Post by vdesigner99 »
Hello folks!
The general question I have and have been pondering for a while since I acquired my 84 is the availability of parts. I have spent the last year cleaning and replacing as many parts as I can remove with out making the car non functional. But whenever I dive into a vendors web site most parts stop at 83.
Is there a huge difference between the 80-83 and the 84? Did 84 cause a major design change? I know the dash changed but everything else seems the same. Any body have a general idea about this? As for the condition of my Azzurro met 876 and runs great. Ive had a few challenges with overheating but with the helpful members of this site I got it worked out. As with any investment/hobby Ive reached a point that it runs great so leave it alone. But I itching to upgrade to better brakes, Allison s ignition flywheel,starter and several other items. I picked it up for 5k, I've probably added 2k and would love to add another 3k but am afraid its just throwing money into a pretty blue bucket. I do get the head turns and frequent compliments. `
Happy Halloween!
Victor
1971 MGB Roadster (sold)
1977 fiat 124 (sold)
2010 Prius
2001 Sequoia
2006 20' REgal bowrider boat.
1984 Pinanfarina
SunnySideUp
Your car is a: SOLD
Re: 84 Azzurro Pininfarina
Post by SunnySideUp »
Nice looking Spider! "Azzurro Met 876" is the paint color code. In the US, the '83-'85 Spiders are known as the Pininfarina Azzurra.
When Pininfarina took over the Spider in '83, the interior dash configuration, location of the exterior mirrors, and the deletion of the back seat in favor of a true parcel shelf and power windows are about the only significant upgrades. Pininfarina also relocated the windshield washer bottle to be under the cowl rather than up near the radiator. In '85 Pininfarina also reworked the radiator so that the overflow tank is the highest point in the cooling system. Other than that - it's the same as the fuel injected Fiat Spider 2000 series ('80.5 - '82). With that in mind, the availability of parts shouldn't be an issue with the exception of one or two interior parts. I believe that air conditioning was ALWAYS a dealer-added option on these cars. If you have AC on your car, you are pretty much left to your own devices and knowledge of your mechanic or AC specialty shop. It is estimated that having AC on a Spider takes away about 3 to 5 horsepower when it is in operation.
As for performance upgrades, a big brake kit and Computronix ignition system are hands-down the biggest bang for the buck. The Computronix igntion improves reliability exponentially (no points or vacuum advance or magnetic pick-up to worry about) and the big brakes will have it stopping on a dime. I have both of these upgrades on my '82 and they are well worth it. I wouldn't bother with a lightened flywheel until you have to replace the clutch or pull the transmission for some reason - but it would be a worth-while upgrade at that time. Everything else is small tweaks here and there. You can opt for some adjustable cam pulleys to dial-in the valve timing. Best to do that if you upgrade the cams. You can also swap out the stock crank and water pump pulleys to aluminum versions to save some weight (same principle as the lightened flywheel). You can also shed some significant weight (and therefore help performance) by removing the big tube bumpers. Adding a rear sway bar will help with cornering, especially if you intend to keep the stock 14" wheels you currently have on the car. Upgrading the shocks is paramount, especially if the car still has its factory-issued set. For high performance go for Koni Yellow. For a good upgrade over stock but less harsh ride than the Konis go for KYB. A set of progressive rate springs will lower the stance of the car an inch or so but still give a nice ride. If you don't have to go through emissions in your area you can get an extra horsepower or two by removing the catalytic converter but be ready for a louder exhaust tone unless you put in a resonator in its place. It is also good to find a way to get outside air to your air box so that it is not ingesting hot air from the engine compartment. All this is well within your $3000 budget, especially if you do some of the work yourself. After that, getting extra oomph from the engine and better handling will get expensive very quickly.
There's a unique enthusiast site just for the Pininfarina Azzurra: http://www.pininfarinaazzurra.com/. But for maintaining it, resolving issues, and getting help, this site you're on right now - FiatSpider.com - is the best.
SunnySideUp
TX82FIAT
Post by TX82FIAT »
The later models have rack & pinion steering so some difference there as well. But the head, block, computer, transmission, and all that stuff should be the same unless modified by prior owner.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
vdesigner99
Contact:
Thank you so much SunnySideUp and TX82FIAT for you excellent info. I think you helped me decide on the brakes and ignition, time to moonlight for funds.
Victor
2010 Prius
2001 Sequoia
1984 Pinanfarina
davery
Your car is a: 1985 Spider
Post by davery »
vdesigner99 wrote:Hello folks!
Happy Halloween!
Victor
That looks familiar.
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
