Remove Fuel injector Retainer Plate
ralphcap
Post by ralphcap »
I recently purchased a rebuilt fuel injector. It did not come with a "retainer plate" (my terminology). How do I remove the retainer plate from the old fuel injector so I can install it on the new fuel injector?
divace73
Re: Remove Fuel injector Retainer Plate
Post by divace73 »
from memory and this is from memory, you should be able to take of the larger rubber seal (which is rock hard by now) and then it should slide of..
Cheers David
see my >>You tube channel<<
vandor
Post by vandor »
Correct. The large seal goes around the body of the injector and it can be pried off.
