Help
Eurotrash124
Help
Post by Eurotrash124 »
I have a 69 fiat 124 spyder with 132c2 040 Engine
It's starts and runs fine but as soon as I let go of the gas and goes to idle it dies ????
It just started doing this after I raced it ?
bradartigue
Re: Help
Post by bradartigue »
Sounds like an air leak.
Eurotrash124
Re: Help
I checked all the vacuum hoses just replaced the intank manifold gasket . Checked out the carb . Replaced spark plugs tested the fuel pump raised the idle ran sacked it pretty much and still can't find the leak or problem any other ideas ?
bradartigue
Re: Help
Maybe the throttle stop screw lost its position or fell out. Does the car have an idle jet solenoid? It may be unplugged or the solenoid is bad.
Eurotrash124
Re: Help
Checked the throttle screw it's fine . But the idle jet solenoid ? What is that where would it be located how do I know if I have one or not , do you have a picture of one ?
bradartigue
Re: Help
First, and not to be offensive, do some research on your own - these parts are discussed so often you should search the forum first.
The idle solenoid sticks out of the side of the carburetor and has a wire connected to it. You either have one or you don't. Most ADFA carburetors have them, so look and see if there is a solenoid sticking out of the primary side of the carburetor. It will look like a 3/4" barrel and have a plug end on it. If it isn't connected then connect to the +12V lead that comes off the firewall (and is long enough to reach it). They can come disconnected if the engine moves a lot and you have soft engine mounts.
BwBrown
Your car is a: 1970 Spider
Re: Help
Post by BwBrown »
Don't remember which years have them, but check to see if you have a dual point distributor?
There is a relay that switches from the start points to the run points.
Dushore, in Northeast PA
1970 124 Spider (red) and a 1979 2000 Spider (Ferrari yellow)
Also: a pair of 1952 MGTDs
1972 Fiat 850 Spider
1965 Chevelle SS Convertible
1975 Corvette
1986 Lada Niva
