Gas leak
FiatJim
Patron 2024
Patron 2024
Your car is a: 1973 spider refurbished
Gas leak
Post by FiatJim »
First the particulars: 1973 spider, refurb'd 3 years ago.
It has started to leak gas, after a fillup. The first time it happened, I did not pay close enough attention and had filled up into the tube. :oops: After that, the car will leak even when filled to below the filler tube. The dripping does stop, so I believe the problem is not in the tank itself. The dripping is coming off from the frame, under the gas cap and not the tank. I am trying to determine: 1) the filler tube became loose or 2) something else has been messed up. I appreciate all ideas.
Jim
bradartigue
Re: Gas leak
Post by bradartigue »
There is a filler tube (big one) and an overflow tube (small one). 73 Spider has top-mounted hoses to/from the engine compartment. Inspect all of them; modern fuels are pretty harsh and can deteriorate the old hoses quickly.
azruss
Re: Gas leak
Post by azruss »
I'm with Brad. I put my money on the big rubber tube from the fill tube to the tank. you will need to remove the corner rocker panel to get to it. AR carries a replacement.
scottmercer
Re: Gas leak
Post by scottmercer »
Hi FiatJim,
I have the same issue on my '78. Did it turn out to be the filler hose? If no, how did you fix it? Thanks! Scott
