I am starting to work on my Spider 2000 I purchased last year. It is a Legend Turbo minus the original motor. The current motor has a 28/32 ADHA carb, although I have not been able to find the engine # to determine exactly what it is.
I am considering changing the carb and intake on the car. How much should a used single plane intake cost? I found one for $20, but that sounds awfully inexpensive.
Thanks for your input!
Brian
I am reposting this in the engine thread where it belongs!
Carb/Manifold Swap
I bought my intake for $25.00 so it is in line. Are you going to purchase a 34 ADF Carb or something different? I put the 34 ADF with 1800 intake on my 79 spider, (originally had the 28/32 ADHA Carb with stock dual plane intake), and I can notice a difference. there is more power as I wind her out thru the gears and the car seems to "breathe" easier...
good luck and have fun.
SpyderJoe
79 Spider - 34 ADF w/ 1800 intake
Is there a less expensive alternative I can use with the single plane manifold? I'm not able to spent $500 at a time for a weekend car no matter how much I like fiddling with it!
OK, I went back and read the article on mirafiori, and it looks like my best bet is a 32DMS or a 32ADFA. Pierce Manifold didn't have any 32 ADFA. I assume the DMS and 32 ADFA are no longer being produced? Are they readily available used?
Also, I have a friend who owns a machine shop, so I can probably get some work done for a decent price. When I get a single plane manifold is there any thing I should ask him to do to it? I'm planning on having him clean it up and bead blast it, but is it worth it to modify the ports?
brian
brian
