A few drips coming from around the oil filter or what I think is the low oil pressure unit.
I tightened both before but it still drips (although less now I think) when engine is running. Do I need a brass washer or something between the low oil pressure sensor and the engine? Or should I tighten it more? I just don't want to break something.
Annoying minor oil leak
- rjkoop
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
Re: Annoying minor oil leak
Yes, there has to be a sealing washer between the oil pressure sender and the engine.
- rjkoop
Cool. That's probably where my leak is coming from. I'll take a look around. Maybe I forgot to put it back on. I can't remember... Can I take off the oil pressure sending unit without all the oil coming out? I'd like to remove it and bring it to a parts store to make sure I get the correct size.vandor wrote:Yes, there has to be a sealing washer between the oil pressure sender and the engine.
Oil leaks are REALLY annoying!
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
- KevAndAndi
- Your car is a: 1981 Fiat Spider 2000
I'm looking to add an oil pressure sending unit, and I also would like to know if oil needs to be drained to do that job.
Kevin
1981 Spider 2000
1981 Spider 2000
- rjkoop
For me I needed to drain it. I removed the oil pressure sending unit and the oil started coming out. My car was on the ground. I drained the oil, found a washer, used teflon tape on the threads and put it back on. Hopefully this will fix my leak.KevAndAndi wrote:I'm looking to add an oil pressure sending unit, and I also would like to know if oil needs to be drained to do that job.
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
- azruss
the sending unit needs to ground through the threads. take the thread tape off
- rjkoop
Will do. Thanks.azruss wrote:the sending unit needs to ground through the threads. take the thread tape off
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
Look carefully.
My sender leaked oil thru the body itself.
- rjkoop
Will do. I still have a drip once in a while. Think I'll have to clean and look more closely. But I think that will wait until end of year.wizard124 wrote:Look carefully.
Richard
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
