Noticed that one of my headlights is pointing far too high. What's the procedure for adjusting? I'm thinking...
- take off the bezel and I should see an adjustment screws from up/down and left/right
- drive the car about 20' from a wall and ensure on flat ground
- adjust lights to ensure they are pointing straight ahead
- adjust lights to ensure that the beam is about the height of my hood from 20' away
Does this sound about right? Did some searching on these forums and couldn't find much.
Headlight angle adjustment
- rjkoop
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
- spiderdan
Re: Headlight angle adjustment
Richard
Try page 46
http://fiatspiderron.nl/PDF%20Files/Fia ... 201980.pdf
This might help also
https://youtu.be/maEWAa6QDv4
Good luck
Try page 46
Good luck
Dan
"Angelina"
2015 Toyota Camry XSE (hers)
"Angelina"
- rjkoop
Perfect. Thanks.spiderdan wrote:Richard
Try page 46
Good luck
Richard
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
- Patron 2024
Interesting how the manual states " replace Headlight bulbs with same wattage" other wise the alternator could be over loaded and does not mention the ignition switch, headlight switch and hi/lo beam switch being overloaded and failing prematurely. I believe higher wattage contributes to all of these issues.
Owners manuals are not meant to over-complicate explanations and define possible future issues. After all, you just purchased your new Fiat, assembled with state of the art technology.
- bradartigue
When manufactured the system was adequate for demand (okay, barely, but still adequate). You're diagnosing problems with devices and wiring made to work 20, 30 years past their expiration date.spider2081 wrote:Interesting how the manual states " replace Headlight bulbs with same wattage" other wise the alternator could be over loaded and does not mention the ignition switch, headlight switch and hi/lo beam switch being overloaded and failing prematurely. I believe higher wattage contributes to all of these issues.
1970 124 Spider
http://www.artigue.com/fiat
- spiderdan
From page 46...AriK wrote:Owners manuals are not meant to over-complicate explanations
Removal...Slacken 4 screws "D"
Picture above clearly shows 3 "D" screws
Dan
"Angelina"
"Angelina"
Hopefully this is not one of those jobs that mushrooms for you. I realized on my car headlights were pointing down and out. Thought, simple adjustment and took a look to see the prior owner had used the wrong type of screws for the adjustments on one side and mangles the locking metal ring. Not a hard job but one that takes a little patience. I had to take apart the other side to see how it should really be assembled. It all worked out well as I did the headlight relay while in there. Project creep.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
- rjkoop
Yep. I took off the bezels and saw the screws but they seemed very rusted and all the way in. But hopefully they can be adjusted. We'll see. Don't want project creep.TX82FIAT wrote:Hopefully this is not one of those jobs that mushrooms for you. I realized on my car headlights were pointing down and out. Thought, simple adjustment and took a look to see the prior owner had used the wrong type of screws for the adjustments on one side and mangles the locking metal ring. Not a hard job but one that takes a little patience. I had to take apart the other side to see how it should really be assembled. It all worked out well as I did the headlight relay while in there. Project creep.
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
- bradartigue
Shop manuals show how to do it, the distance of the headlight to a wall, where they should hit, etc.
1970 124 Spider
- rjkoop
K. I'll check. For now found the adjustment screws and they worked fine. So I just ensured they were pointing straight ahead and the height was about right and even between the 2 headlights.bradartigue wrote:Shop manuals show how to do it, the distance of the headlight to a wall, where they should hit, etc.
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
- bradartigue
1970 124 Spider
