Hello all,
1st, let me say that this site has been a godsend for me. Thank you for all the tech info! What a great resource!
Since the late 80's I have been a fan of the X1/9 and I now own my 3rd. I have always wanted a Spider and ran across a 1980 FI Spider in decent shape with no body rust/cancer but it would not start. After a few minutes of negotiation, I was able to purchase it for $1,100.
[img][IMG]http://i1006.photobucket.com/albums/af183/screamindave/Spider_zpscfdidbjv.jpg[/img][/img]
Using this website and the links to Brad Artigues website for diagnostic info, I was able to get it started and barely idling. After further inspection I found that it needed a new mag p/up.
I also noticed that the distributor did not have a vacuum advance and that the distributor looked wrong. Can any identify this distributor?
[img][IMG]http://i1006.photobucket.com/albums/af183/screamindave/Spider%20Dist%201_zpss0hnnhkj.jpg[/img][/img]
[img][IMG]http://i1006.photobucket.com/albums/af183/screamindave/Spider%20Dist%202_zpshckhfaqj.jpg[/img][/img]
Distributor identification help needed - 1980 Spider
- Your car is a: 1980 124 Spider 2000
Dave Currans
Woodstock GA
1980 Fiat 124 Spider
1981 Fiat X1/9
Woodstock GA
1981 Fiat X1/9
- Patron 2019
Re: Distributor identification help needed - 1980 Spider
Your pictures are not posting
This link will help
http://www.fiatspider.com/f08/viewtopic ... re#p246075
This link will help
Current 81 Spider 2000
Previous 76 Spider
Previous 76 Spider
- divace73
- Your car is a: 1980 Fiat 124 Spider Silver
I can't see the pics either, however if it is similar looking to the spider unit without the vacuum bit, it could either be removed altogether or a unit from a 131 (In Aus the 131 didn't have the vacumm capsule)
Cheers David
see my >>You tube channel<<
- Your car is a: 1970 128
Picture links now in original post.
Dave Currans
Woodstock GA
1981 Fiat X1/9
Woodstock GA
1981 Fiat X1/9
- divace73
ironically that is how my car will eventually look like minus the big bumpers, I even desire the luggage rack but do not want to put holes in my boot lid
I have just noticed the weights are missing from the holes
Cheers David
They're not weights, they're a type of bush I suppose you'd call it, to hold the weight up off the plate to reduce friction.divace73 wrote:I have just noticed the weights are missing from the holes
Mick.
- divace73
oh, I thought the dimple before the bush did that??? It's made me curious I'll have to look at may spare dizzy now.131 wrote:They're not weights, they're a type of bush I suppose you'd call it, to hold the weight up off the plate to reduce friction.divace73 wrote:I have just noticed the weights are missing from the holes
Cheers David
