124 Engine Swap
- Your car is a: 1976 Fiat Spider
124 Engine Swap
Can an engine from a 1978 124 be installed into a 1976? I know the answer is on the forum somewhere, but I can't find it.
1976 Fiat 124 Spider
- riverdadd
- Your car is a: 1975 Fiat Spider 1977 Alfa Spider
Re: 124 Engine Swap
it should be a straight forward swap....... same motor
Re: 124 Engine Swap
the only difference in those years was the air pump and alternator mounting
Re: 124 Engine Swap
The alternator on the '78 is on the left (intake) side, and cannot be easily moved to the passenger side as it runs on a different groove on the crank. The crank pullies are not interchangeable, but you could have one custom made.
