So went looking at the vendor sites for one of these. No such luck
So I did a hasty repair. Welded both sides then ground down the weld.
Then decided to add additional metal. This piece might be overkill.
Decided 18 gauge would be a better choice. So set up the fabrication equipment (harbor freight body hammer and dolly)
Then welded and ground, remember hasty fix.
Paint and install.
Test drive went fine.
Now the questions. What caused this?
New guibo and center support bearning less than 1 year old. New u-joints again less than 1 year old. Drive shaft alignment marks are still aligned and weights all still seem to be attached to drive shaft. No unusual vibrations. I do drive it hard though. Engine is stock.
Does anyone have one of these laying around I could have? (1985 if it makes a difference)
