Hello, I am putting in a transmission on a 1976 Fiat Spider and i'm not quite sure how to assemble the lower part of the gearshift(trianngle cover underneath). This is what I have:
1. Gear Lever
2. spring
3. big half-oval cover
4. smaller half oval cover
5. black triangle mounting piece
6. metal triangle cover
7. nut and washer
Any help on the order these go would be appreciated!
Thanks,
Kevin
1976 Fiat Spider Lower Gear Shift assembly
Re: 1976 Fiat Spider Lower Gear Shift assembly
From top to bottom they go like this:
1. Gear Lever
2. spring
3. big half-oval cover, metal
4. PLASTIC black triangle mounting piece
5. smaller half oval cover, metal
6. 8mm (13mm wrench) nut and washer - USE A NYLOCK nut!
7. metal triangle cover
1. Gear Lever
2. spring
