Picked up a carb spacer and gaskets for the 72's stock DHSA carb this past week, hoping to end the heat soak/no start issues. Pretty obvious on a visual check that I'll need longer carb studs than the ones currently installed. Anyone out there know the length/thread pitch/diameter for the studs, in order to accommodate the 14mm spacer?
Neil
Carb to manifold studs: size/thread info?
Neil O'Connor
Madison, WI
72 FIAT 124 Spider
ex-71 FIAT 124 Coupe
Madison, WI
72 FIAT 124 Spider
