Hi
My '82 starts fine when cold but won't start when hot. When I turn they key I can hear an electric/mechanical whirr from behind the passenger dash, but it won't turn over.
This guy with the same issue in his 850 - thread thinks its a grounding issue. Could the ground be the problem in a 124?
http://www.fiatspider.com/f08/viewtopic ... 12#p243312
Also, when cold, sometimes it won't start in park, but it will in neutral. Any thoughts on that?
Thanks!
'82 won't start when hot
- Your car is a: 1982 Spider
- Your car is a: 1970 128
