stock rim size and tire size? options in changing?
NickSpider
Post by NickSpider »
Ok I have a 75 124 spider 1800. I am thinking the rusted rims on it now are 13" x 5.5 but just guessing, does this sound correct?
What are my options in changing the rims out, 13's 14's etc. also what tire size it best for the 13" rim and 14". I am looking to keep fiat rims, not necessarily 75 model ones, but ones that will definately fit without having to do any spacers.
Any help is greatly appreciated
Re: stock rim size and tire size? options in changing?
there weren't many options with oem wheels, even the alloys are 13 x5.5. The exception is some of the late Spiders and Turbos had 14" wheels. If you want sort of a stock looking ride, go with 185x60x13.
NickSpider
So Cal Mark wrote:there weren't many options with oem wheels, even the alloys are 13 x5.5. The exception is some of the late Spiders and Turbos had 14" wheels. If you want sort of a stock looking ride, go with 185x60x13.
What size are you using on yours? I am not quite sure what I should do, I just need to get some new tires so I can move it in and out of my garage easier. Eventually I would like to get some new wheels or alloys for the fiat.
I have 185x60x13 on mine
FMO
Post by FMO »
Hi! I am running on 205/60-13 on my Crommodore CD 39 rims, it looks great and the handling is very good :-) :
http://home.online.no/~ellholt/fiat124s ... =&pExPic=0;
Regards
FMO
FMO
Post by FMO »
By the way , the Crommodore CD 39 is 13X6.o :-)
Leesfer
Post by Leesfer »
Do 205 fit on a 5.5 rim?
NickSpider
I decided to go with the Kumho in size 185/70/13. Look to be pretty good tires.
