Copper washer
micbrody
Your car is a: 1981 fiat 2000
Copper washer
Post by micbrody »
I recently had to remove caliper to retap bleed screw. All went well. Brakes work fine......but I noticed I forgot to install copper crush washer when reconnecting caliper to brake line. I don't see any brake fluid leaks. Do I need this washer re-installed?
Re: Copper washer
yes, that's the seal for the banjo bolt
