DMSA diagram
V12StealthHunter
Your car is a: 1971 Fiat 124 Spider
DMSA diagram
Post by V12StealthHunter »
I bought a rebuilt 32/32 DMSA and I was looking to see if someone could help label all these ports for me.
1. ??
2. ??
3. ??
4. Plug this?
5. Plug this?
6. Vent to air cleaner
7. To bobina per electrovalvola?
I'm installing it into a 1971 1.6L car which has the original DHSA2 still installed.
Link to photo; http://3.bp.blogspot.com/-b3IpxN5fcfc/V ... 0e1280.jpg
1971 Fiat 124 Sport Spider
RoyBatty
Re: DMSA diagram
Post by RoyBatty »
2 is fuel inlet, 3 is return to tank, 1 is bowl vent to an emissions device, I believe a valve that goes to the charcoal canister.
Had to look at a carb out in the garage.
aj81spider
Re: DMSA diagram
Post by aj81spider »
I'm not sure that's right. I'll check in the morning but I believe my DMSA is connected with 2 as inlet; 3 as return; 1 is the bowl vent.
4 and 5 are vacuum ports that I plugged.
6 goes to the air cleaner - small port nippled off the big port that has the crankcase breather hose attached.
7 I left unconnected. I believe it goes to emissions control equipment that was stripped from my car.
A.J.
2006 Corvette
bradartigue
Re: DMSA diagram
Post by bradartigue »
To confirm - the angled one is bigger and is the fuel IN. The one above it has a very small orifice inside the casting, it is the fuel OUT. The other is the vent.
