Sqeeky steering wheel on a 1985 SpiderEuropa
Marangen
Post by Marangen »
What can be the prob?
Mostly at 12/noon position +/- 5 mins. I try to bend steering wheel/column up and it goes away temporarily...
Any ideas?
focodave
Your car is a: 1980 Spider 2000 F.I.
Re: Sqeeky steering wheel on a 1985 SpiderEuropa
Post by focodave »
My 1980 had a similar problem.
It turned out to be the steering wheel hub rubbing on the plastic column switch cover shown below:
I simply re-positioned the column switch cover so the hub did not touch it and the "squeak" went away.
If that doesn't solve your problem, you may have a noisy u-joint in the steering shaft. Loosening the 4 column bolts and slightly re-positioning the column may make the noise go away.
1970 MGB GT (my other hobby)
Marangen
Post by Marangen »
All solved now thanks.
Removed the cover and could (I thought) locate area, juust near steering wheel itself. So with some lubrication spray and turning the wheel many times, the squeeking sound went away!
Yes. Victory. Very annoying sound.
