Fiat Spider 2000, 1980
basso
Your car is a: 1981 Fiat 124 Spider 2000
Post by basso »
Hy everone,
i am from germany and actually rebuilding my Spider.
I had a Spider 15 Jears ago but this Spider was a lousy bit of metal and ended in a very sad spider story (it was given back to the seller). Two years ago i bought my second, the actual Spider.
It happend that my second rideout ended in wrecking at the top of a bridge (the lagest Bridge in Hamburg).
First time in my life i have to wait at the beginning of an traffic jam...
Later i was trying to find the reason for the boiling water i noticed that my fan was not connected.
While searching for other errors the list of non-working-things got longer and longer.
After two pages of mistakes one thing was clear: If i ever would like to have an Spider i can relay on ( a joke ;) he must be completely overhault, and the story began.
Id like to share my ongoing process of the complete restauration and: train my english...
basso
basso
Re: Fiat Spider 2000, 1980
Post by basso »
My aim is to renew everything wich cant be rebuild and amazing, but nearly everything can be overhault.
I started with the ignition coil. there are a few types used, mine is a Bosch Coil and this was the beginning point:
After testing the Coil i started to "sandblast" everything carefully ( i use copper slag (dont know if this is the correct word ;) ))
repaint everything and printed the original Sticker ( i am a graphic designer).
and here ist the result:
in my opinion it looks like fabric new...
Basso
basso
Post by basso »
a very difficult thing to do is to build up a new Cable harnes for the whole Spider.
I decideed to use different plugs than the old: AMP SUPER SEAL. They are waterproof and a bit smaller than the old.
I started with the smaler pieces, but take a look at the pictures.
If You ever like to build Your own cable harnes be sure to use the correct plan (most contain a few errors) and use the original cable colors (otherwise You will mix up wires wich will lead You to blowing fuses) .
Here is the brand new cable harnes fpr the instruments:
Every harnes is labeled: the used wire thickness,the wire type (FLRy) etc. and every plug got a label where to fit.
this is necessary because the AMP seals cant be coded.
BEEK
Your car is a: 1975 Spider
Post by BEEK »
nice work!
75 spider
son has 78 spider
AriK
Post by AriK »
Hallo Freund! I'm following your wiring restomods with interest. If you get stumped or if you need to confirm your wiring diagrams do a google search on " Brad Artigue wiring". It is all documented on a year to year basis for the Fiat Spider.
Please proceed to share your progress with us.
Ari
basso
Post by basso »
AriK wrote:Hallo Freund! I'm following your wiring restomods with interest. If you get stumped or if you need to confirm your wiring diagrams do a google search on " Brad Artigue wiring". It is all documented on a year to year basis for the Fiat Spider.
Ari
This exactly my source. It is the best wiring diagram, but there are two connctor marks lost (in my pdf).
I improved the Wiring diagram using all the hacks that i could find (brown wire etc.).
i also added window opener modules, seat heating ( it is cold in germany) another improvement can be seen in my next post - the fuses!
4uall
Post by 4uall »
That is beautiful. Wish we lived closer 8)
basso
Post by basso »
the fusebox.
Id like to add a few more fuses for seatheating, windowmodules etc. and was in need to have more fuses in the box ( i dont like to add them on the relayboard). So i decide to switch all the fuses to be small modern fuses.
There are sets of minifuse mountings (correct word?) wich can be sticked together. This is what i did.
i mounted the fuseblock in to the old fusebox - it works great.
And here is a photo of the main cable harness beeing build.
Basso
4uall
Post by 4uall »
I wish my brain worked like that. Do I dare say that wiring is beautiful 8)
basso
Post by basso »
the photos are shot a few weeks ago. Testing is nearly finished – everythings works exept the hazard switch.
I have read that the hazardswitch relay needs "full" power to work - is that correct?
Are You interessted in my clock overhaul? There is no need to buy a special glass....
My glass is out of an spot (halogen). i simply drilled a whole by using a diamant dremel the dimension is the same!!!
these glass halogen-spot-covers can be bought separate.
The alloy ring is back and airbrushed in semigloss black
AriK
Post by AriK »
Innovative. And typical German discipline :) i mean that as a compliment, dont take that remark any other way. It helps us understand why these cars in that market retail for 1.5 times more than in Canada ( or 2 times more than in the states).
P.S. I got my glass off a portable air compressor. My compressor now has no more visor but at least have a beautiful clock facade :wink:
aj81spider
Post by aj81spider »
I like the fuse box idea. What did you use for the mini-fuse mounting and where did you get them? Do the connections come out the back like the current box?
A.J.
2006 Corvette
basso
Post by basso »
a bit more electrical stuff - the power windowmotors.
When i first try to open the Windows it feels like beeing in a slomo-movie – 2 Minutes and the window stopped a few centimeters before end.
i checked the motors an they where in a really bad condition.
Here is the rusty piece in parts:
The motor can be opened by carefully defolding the little flaps on the back.
i usally scetch all parts while removing...
The rest is cleaning de-rusting and painting everything and after all is done the overhault motor
runs faster (and stronger) than ever ;)
basso
Post by basso »
aj81spider wrote:I like the fuse box idea. What did you use for the mini-fuse mounting and where did you get them? Do the connections come out the back like the current box?
I ordered the mini fuse holder at a technical suppliers store in hamburg. For this update You need to remove all the old holders and their fittings. inside of the fusebox everything was sanded to fit ( depending on the shape of the fuseholders)
the fuseholders can bee snapped to one big block. this block was glued into the box – thats it.
Ptoneill
Post by Ptoneill »
Very nice work...as for your power windows check your cable rollers. Several of mine were severely worn and were dragging the motor down.
Stay Safe,
Pat
79spider
HAVE FUN!! It's a FIAT!!
ptoneill@msn.com
