When I signal for a left turn the light/stalk does not automatically return to the off position. Right turn works fine. This is a brand new column switch...thoughts?
turn signal switch question
Re: turn signal switch question
When you installed the switch, you might not have correctly positioned the cancelling ring. I don't have a photo, but I bet somebody else does.
Mine did this, turned out to be that the steering wheel was not centered when the wheels were straight ahead, and PO had adjusted the tie rods to make it appear that all was correct. But the turn signal return would only work in one direction.
