With the new Koni's came a nice little bag of hardware. Reading the mildly inscrutable paper direction enclosed, it looks to me like the hardware is supposed to bolt up like so (new bottom bolt used for illustration only):
From left to right: 2 nuts, 1 large flat washer, 1 rubber washer inserted over steel sleeve, 2nd rubber washer (also inserted over sleeve), large flat washer, then shock body. Good so far.
First flat washer and lower rubber washer went on the shock shaft no problem. Steel sleeve went as far as the bottom of the threads....and stopped.
Top view of sleeve on threads:
The old shocks had a similar steel sleeve, a tad shorter and narrower. I suspect installing without the sleeves would be a Bad Idea (tm), since the shock could eventually slop around the top fender hole causing damage. Do I need to find different sleeves at a local Koni purveyor, or are there other suggestions?
Thanks, as always.
Neil
(And, no, I just can't wait to balance all this underneath the intake manifold....
