1979 Fiat Spider Stuck Accelerating or Idles Extremly High
Willards9
Post by Willards9 »
Greetings Everyone,
I apologize if this has been tackled before in another thread with a better title but it's a thread I have been unable to find. I have a 1979 Fiat Spider that is, for a lack of a better term, stuck accelerating. So the last few times I drove the car I encountered a problem with the car continuing to hold power almost like engaging cruise control on a modern vehicle. The only way to remedy this was to take the car out of gear, press and release the gas pedal a few times. The three or four times it did this it was corrected almost immediately by exercising the above remedy. However, this past winter I was staring and warming up my Fiat for its monthly run to keep everything operational, and it happened but messing with the pedal would not correct it. Now I'm stuck with a car that starts right up but idles at 3500+ RPMs. I have tinkered with the carb on my own for the last few weeks trying to correct the issue to no avail. I've also searched a plethora of forums but haven't found anything similar or helpful. I would appreciate some assistance with this matter. Something has to be stuck causing the car to rev the engine up to 3500+ RPMs. I appreciate the assistance with this matter and thank everyone in advance for the input.
Best,
BW Schimke
kenncarp
Your car is a: 1979 Pininfarina 124 Spider
Re: 1979 Fiat Spider Stuck Accelerating or Idles Extremly High
Post by kenncarp »
Check all of your throttle linkage. My 79 did that a couple times, and it ended up being the lever that connects to the rod, which connects to the carb, i dont know the name for it, kept getting stuck. I would also check to make sure your flaps in your barrels are somehow stuck open. Good luck!
1979 Fiat 124 Spider (Red and Black Restoration)
1980 Fiat 124 Spider (Red parts Car/Autocross car)
1986 Toyota Tercel Wagon
17 Year Old Automotive Mechanical Engineer
bobplyler
Patron 2022
Patron 2022
Post by bobplyler »
The best way to fix that is to replace the carb. A plus is that you will notice much better performance. You can use the stock manifold, but a single plane will provide even better performance (but it's not necessary).
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
spidernut
Post by spidernut »
1. The most likely culprit is a sticking fast idle mechanism. It is operated by the choke. The internal parts can get sticky and cause this issue. Remove the choke, inspect, clean and lubricate and you should have the problem solved.
See items 58-64...this is what gets gunked up and sticks
2. Check your linkage and the spring in this photo:
3. Check your floor mat to ensure it isn't getting caught on the pedal
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
