Has anybody experienced a sticky clutch release?
I find that after the car has warmed up the clutch seems to not have a smooth release. It's as if the cable needs lubricating or perhaps it's an adjustment. Is this a common problem? The clutch is new.
Jim
Sticky clutch release
- Your car is a: 1980 spider 2000
Re: Sticky clutch release
yes, i have. i am a little worried about it. any attempt at a normal, smooth release will stall the engine. i have to rev slightly for that moment when it starts 'letting go'. i am worried that i am slowly cooking off my clutch. i assume i will have to get a new clutch sometime very soon. eagerly watching to see if anyone has some wisdom to offer.
- mik
- Your car is a: 1982 Fiat 124 Spider
Check the clutch pedal fork where the cable attaches: it may need grease or the end of the cable may not be completely seated.
Did you replace the cable when you pulled the engine?
I've found that the cable over time can start to bind. I also added an additional ground strap from the engine to the body.
No, I did not replace the cable.
I will install another ground strap and grease the links and see what happens.
Thanks,
Jim
Thanks,
Jim
Might consider a cable replacement. The sticky cable might start to flex the firewall and over time a crack will develop.
The extra ground strap is just an added bit of caution as if the original ground is not great, then the clutch cable can act as a ground wire causing issues like you are describing. I went to Lordco and bought some battery wire, soldered a couple of connections on and went from the lower studs on the passenger side of the engine to a stud for the radiator nuts.
- kenncarp
- Your car is a: 1979 Pininfarina 124 Spider
Its funny, my dad totally denies the car does it, but i notice it does. On take off or shifting when you go to release it it is super choppy and cant be relased smoothly. Its a lot harder to get a smooth takeoff, because it just sticks and jumps. I havent found a solution.
1979 Fiat 124 Spider (Red and Black Restoration)
1980 Fiat 124 Spider (Red parts Car/Autocross car)
1986 Toyota Tercel Wagon
17 Year Old Automotive Mechanical Engineer
