Has any one tried this Electronic Ignition Conversion Kit
lurch
Your car is a: 1975 fiat spider
Post by lurch »
lurch
Re: Has any one tried this Electronic Ignition Conversion Kit
Post by lurch »
I ordered points from Vic's Auto Sports. They sent me ones that were the wrong direction. They said they were back ordered on the ones I need. They are not even sure they will get the ones I need in. Has anybody tried this conversion kit?
donerehart
Your car is a: 1976 spider
Post by donerehart »
I have had this conversion kit on my 76 for three years and it is fantastic! A little hard to figure out it's installation, but once I got it right it worked great!
76 Spider
St. Louis, MO
lurch
Post by lurch »
Did you have to pull the distributor?
RoyBatty
Post by RoyBatty »
I have one in my Coupe and my Spider. They both run great.
lurch
Post by lurch »
I just watched a youtube video were the guy put it in his car without pulling the distributor sound like it might be my next purchase.
lurch
Post by lurch »
Anyone know if it matters that I have dual points?
RoyBatty
Post by RoyBatty »
Had dual points on my 75 Spider.
The module dropped right into place.
I think it depends on the model of your distributor though.
vandor
Post by vandor »
It will fit all dual points distributors.
jlw35
Your car is a: 1975 spider
Post by jlw35 »
lurch,
do you have a link to the video?
lurch
Post by lurch »
https://www.youtube.com/watch?v=v-HzatlyDRA
Here you go its a mustang but hopefully not much different.
jlw35
Post by jlw35 »
lurch
Post by lurch »
No problem I just ordered one.
Texsardo
Your car is a: 1978 Fiat Spider Convertible 1800
Contact:
Post by Texsardo »
I replaced my dual burn' t out points with the AutoRicambi set. My PO had drilled out the base plate to fit some kind of USA made points for some other car. I had to do a little work on base plate but once it was fitted, perfect, much better. But I am wondering since it set at 10° BTC, do I still need the spin up wings beneath the plate. My timing is stuttering a couple of degrees. Does my distributor still need these since timing is already set at 10° ? I thought I saw a post on this where they removed the weights since their purpose is to change timing to10° after warm up. Anybody know?
Texsardo :?:
vandor
Post by vandor »
No, the weights have nothing to do with warm up, it was the dual point set up that did that.
The weights advance the timing as engine speed goes up, you must have that for the engine to run properly.
