Carburetor Question
- Your car is a: 1979 Pininfarina Spider 2000
Carburetor Question
So I have a 1979 2000cc Spider with the 28/32 ADHA carb on it, and am looking to replace it. I have ordered a 34 DMSA and a single plane 1800cc manifold, and I would like to know for certain if they are compatible. I can't find any reason to think that it wouldn't be after I replaced the manifold, but I would like to know for certain. If so, any tips to ensure that the replacement goes along smoothly? I am vastly unexperienced, but I am always ready to learn.
Re: Carburetor Question
the new intake won't cover the egr crossover in the cylinder head. You'll have to either change the exhaust manifold or plug the egr tube to prevent an exhaust leak
The easiest thing is to cut and crimp the EGR tube.
Thanks a lot for the advice guys, I'll keep it in mind.
- Your car is a: 79 Spider
I saw a post where they slipped a thin piece of sheet metal under the connection on the exhaust side of the block.So Cal Mark wrote:cut and crimp sounds so final, and irreversible
- Nanonevol
That's what I did. Looks better than a cut and crimp. Considered putting a tiny muffler on the EGR tube (kidding).
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
- Your car is a: 1979 Spider CS2 weber 34adf
i couldn't undo the studs on the exhaust side easily, so i used a welsh plug on the intake side. I think it was 14.5mm. Works a treat
various KTMs and V8's
RR Sport
'79 Spider 2000
RR Sport
'79 Spider 2000
