Or, soak them in gasoline, light them up and run!!
It might have to revert to that, I shouldn't have fixed my flaming exhauast
push the sleeve out of the middle, then push the bushing out
I tried to punch the centers out but not much luck, I was a bit worrried of hitting them to hard and doing damage.
I figure I'll try to cut some of the rubber away and hammer them out using a socket about the same size. At any rate, I will have time to figure it out, the bolt threads are completely shot so I'll have to order some.
I was wondering if I bought new trailing arms do I put washers on the outside like these?
Thanks for the help guys, I'm getting close, I start him up every day just to hear that engine. Have a great evening
