distributor oil leak????
Hey, I'm looking for the paper gasket under the distributor. I had a seal sent from international but, it was a rubber one maybe for inside the distributor? Does any one know what to ask for when I reorder so I get the rite one?
- Curly
- Your car is a: 1968 AC Coupe and a 1976 CS1 Spider
Re: distributor oil leak????
Why not just make one? if you dont have any gasket paper use some cardboard from a breakfast cereal box and cut it out using the old one as a template. If that doesn't work then order one. I'd describe it as the 'Distributor body to Cam box gasket'.
Curly from Oz
124AC coupe http://gallery.italiancarclub.com/124og ... -AC-coupe/
124CS1 spider http://gallery.italiancarclub.com/124og/curly/album52/
- manoa matt
I've had two of those paper gaskets from vendors fail and leak. Until I made my own out of gasket material available at any auto parts store.
Matt
Matt
