Overheating '77 finally fixed
124Fan
Post by 124Fan »
I had already replaced the water pump and t-stat. Couldn't drive it for more than 10 mins or so without the needle heading straight for the red zone. Finally got over to my Dad's where he had a few known-good radiators from 1608 cars. The 1756 radiator is taller and a little wider with a different fan setup/connector. I have the known-good 1608 radiator in the car now and I'll have to make a few brackets for a more permanent installation.
Not sure how this '77 radiator got so messed up. I've had the car for 10 years and it has always had distilled water and coolant in it. No idea what the previous owner did to it though.
A few years back, I had to replace the T on the front of the head due to massive corrosion. That was probably the first clue that something was not right inside.
When I got the car, it always ran with the temp needle right in the middle (maybe just a hair past). I found this mod the t-stat. The whole is big...3/8" or so. I have this t-stat installed right now and the engine is running a little cool. I have a new t-stat from Vick (which isn't super easy to install) that I put in before. When it didn't help, I removed it, but will likely put it back in.
Sonny
'74 124 Coupe (Gone), '72 124 Spider (Gone), '77 124 Spider (current project)
3rd generation Fiat grease monkey
