1980 fiat radiator question will 1975 radiator work?
ctbob
Post by ctbob »
Hi all. My 1980 Spider carb, needs a radiator. Found a like new complete with fan 1975, will it work ? Thanks Bob
Re: 1980 fiat radiator question will 1975 radiator work?
the 2L radiator was wider than the 1800 radiator, so besides not matching up with the two mounting studs, it will have less cooling capacity
ctbob
Post by ctbob »
Thanks Mark
phaetn
Your car is a: 1974 Fiat Spider 1800
Post by phaetn »
So Cal Mark wrote:the 2L radiator was wider than the 1800 radiator, so besides not matching up with the two mounting studs, it will have less cooling capacity
On a related note, if I can get my hands on a 2L rad locally can I put it into my 1.8? I have a '74. Would it be problematic to make it try and fit by making a mounting bracket?
Thanks and cheers,
phaetn
1974 CS1
32/36 DFEV; CompuTronix ign.
9.8:1 c/r; 40/80 intake cam w/ Isky springs
Vicks' SS header & adj. cam pulleys
A/R's progressive coils, Koni Yellow dampers
205/50-15s on CD-66 style rims
Momo wheel, Corbeau seats w/ 5 pt belt
pics and HD vids
you'd have to remove the mounting studs from the radiator support, and you may have to notch the top of the radiator support for clearance on the top tank. Not a big deal and worth the increased cooling
phaetn
Post by phaetn »
Thanks very much for the speedy reply, Mark!
I'm heading to the FFO -- an 8 or 9 hour ride -- and it will be longest haul in the car by far so I'll see if I can get this done.
Thanks and cheers,
phaetn
1974 CS1
pics and HD vids
fillupd
Your car is a: 1978 Fiat Spider 1800
Post by fillupd »
I installed a fan and aluminum radiator I bought from Mark a few years ago. Best thing I EVER did to my spider. Give me a traffic jam in 105 degree day, no problem.
Good Luck and have fun at the FFO!
