The flange between my exhaust manifold and the down pipe keeps coming loose. At first I thought it was because there was no support bracket between the transmission and the center portion of the exhaust. However, I added the missing bracket and it still loosens at the manifold- down pipe after a hundred miles or so.
I noticed there isn't a spring? retainer on the nuts, is this needed? Also, would copper nuts be any better? It seems copper would be softer? Maybe I should use a second set of jam nuts?
Any suggestions would be appreciated .
Exhaust manifold to down pipe loosens
- Patron 2019
Current 81 Spider 2000
Previous 76 Spider
Previous 76 Spider
Re: Exhaust manifold to down pipe loosens
I double-nut mine.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
Stover nuts
- Patron 2019
Thanks guys!
I have some copper stover nuts, looks like doubling them up with the brass nuts is what I'll try next.
Previous 76 Spider
Previous 76 Spider
