Leaking fuel tank
Italchic
Leaking fuel tank
Post by Italchic »
Went to take my '71 124 out of storage and discovered a slow leak in the fuel tank...what are my options?
riverdadd
Your car is a: 1975 Fiat Spider 1977 Alfa Spider
Re: Leaking fuel tank
Post by riverdadd »
where is the leak's source? maybe you can get lucky and just tighten a clamp. if it is a pin hole then u can get some "gas tank repair putty" and stick a bubble gum sized wad on it.......... if more serious, like a leak @ the seam, then replacement tanks are fairly cheap. or go used..... hope that helps
dimitridodys
Your car is a: 1983 mira
Post by dimitridodys »
In my experience, the epoxy tank patches have been a temporary fix. They will eventually leak.
I finally removed the tank and took it to a radiator shop. They boiled it out and soldered the leaky places.
Ken
Post by Ken »
use a bar soap abn rub it over the leak
spider2081
Patron 2024
Patron 2024
Post by spider2081 »
AR has new tanks with internal baffels and great prices.
Italchic
Post by Italchic »
Thanks for all the info...turns out it was just the hose from the filler pipe to the tank...whew!
