Dot 5 Brake Fluid
Your car is a: 76 124 Spider
Dot 5 Brake Fluid
Post by 76124 »
Anyone running Dot5 Fluid in their Spider? After pulling the motor ands seeing what occasional spills and leakage has done to the paint under the master cylinder and behind the steering box, the thought of fixing all that and having it happen again kills me. Im way more careful than the prior owner of 12 yrs probably was, but still. Dot5 does not eat paint, it being silicone this makes sense. It also does not absorb water like Dot3-4 so long periods of hanging out wont creat problems as they can now.
Thoughts from those who know more?
Kraig
Everett, WA
76 Spider owned just shy 30 yrs and counting
69 Spider - Big truck ate it :cry:
74 Sedan special TC Auto..Died of cancer RIP
81SPIDERMATT
Re: Dot 5 Brake Fluid
Post by 81SPIDERMATT »
i will tell you what I remember from my research ..... using dot 5 it is recommended that you completely flush out current system ... mixing 5 with 3 was not recommended .... some say dot 5 will have softer pedal feel because it holds more air in suspension .... some say dot 5 will absorb moisture and should be change more often than dot 3 .... lots say they use it and love it ... and it does not eat paint as you stated .... brad chimed in on my questions way back and recommended something blue (sorry cant remember ) .... it was great because you could tell when the new fluid was coming out (its blue) ... wish I had more for you .... brakes should not leak ....and mine don't so I never worried much about paint ...and quick cleanup of any spills should work also
you don't want Dot 5, you want Dot5.1
fredguaz
Your car is a: 1977 Fiat Spider
Post by fredguaz »
I use DOT 5 brake fluid on my restored Triumph 750 motorcycle. Both Lockheed calipers were rebuilt with new seals and stainless master cylinders and new hoses. Lockheed recommends against using DOT 5 based on seal swelling but this was dated and many, including me, have used it with zero issues. I do, however flush and bleed the brakes annually. Definitely do not mix the 2. It will gel up. Would highly recommend all new lines and rebuilt/new MC and calipers before switching over. Haven't decided if I'll go DOT 5 on my spider. Paint protection little more critical on a bike. I have noticed that the purple DOT 5 (I purchased from Harley Davidson) turns a murky clear when I flush it (??).
Fred
Lake Norman, NC
1977 Fiat Spider (current project)
1977 Triumph Bonneville 750 (previous project)
1971 Honda CT-70 K0
1972 Honda CT-70 K1
1990 GMC S-15 Jimmy (Daily driver)
ScotcH
Your car is a: 1978 Fiat Spider
Post by ScotcH »
Don't do it. DOT 5 is a much more compressible fluid ... if your brakes are spongy now, they'll be worse with DOT 5. A good quality 3 or 4 is perfectly fine for several years, though ideally you should run 1/2L or so through the system annually.
The Blue fluid is ATE super blue, which is the same as ATE Type 200, just blue dye in it. It is very good fluid used by many track dudes. The super blue is no longer available in NA due to some bullshit DOT rule that brake fluid must be colourless, but the Type 200 is readily available.
8legs Racing - BMW Parts and Performance
- 1978 Fiat Spider (plus 73 and 74 parts cars)
- 2008 BMW M3
- 2003 BMW X5 4.4
- 2000 BMW 330i race car
DieselSpider
Post by DieselSpider »
Don't use synthetic unless you are 100% sure that all rubber in your brake system has been upgraded to a formulation that is compatible with synthetic brake fluid. Mine had NOS brake components in it that failed in less than a year turning to putty from the synthetic brake fluid. It can be a roll of the dice which you can loose at easily. One problem is that much on the shelves out there as DOT3 is really some universal low end synthetic formulation which may not really be mentioned on the labeling except for in a language other than English.
