Punching out or removing converter
I have to replace mid muffler and pipe on my spider.I was thinking about removing the converter or maybe driving a pipe through it to make it free flow,since the exhaust in front of the converter is fairly new.buying an exhaust for an older spider to emit the converter seems to be a waste right now.any thoughts?I think it would run better.we currently have no tailpipe emmissions testing in michigan.so I can do with it what I want.
it will be alot louder once its hollowed. i have a 4.8 chevy v 8. the cats got clogged and the thing wouldnt run. didnt have the 700.00 for new cats so they got opened up. a temp fix till i can pick up new cats. it dosent run as strong as it did when the cats were good. and it did run strong. it has headers from the other guys, full exhaust larger a chip etc. hope to repair soon...
Where are you located? What do you drive?
I have just completed the process on my '80 here in Michigan where there are no emmission laws or tests. Good thing, because I have lost the ability to study for tests.
I have a 3 bolt flange cat for sale. I cannot guaruntee passing emmissions tests with it, but wanna get it off my bench soon. If you are interested, send me an email. It is original 1980.
I have over the past two seasons replaced everything from the cat back. ANSA dual tipped muffler, exhaust pipe with resonator, and just put on a "test" pipe dropping the cat.
The cat was replaced one entire driving season apart from the other two items. They were replaced last season with pleasing sound quality results.
I have experienced zero sound differences with the test pipe; which I obtained from BRUCES at http://www.fiatparts.com
Punching out your cat will more than likely cause more problems than it was intended to resolve.
exactly, but i know some areas only require you to pass a visual inspection and if you look like you got a cat then you are okSo Cal Mark wrote:when cats glow red it's because they're loaded with unburned fuel, either from an overly rich mixture or a misfire. It doesn't take too long for them to melt down in that situation. Excellent external condition doesn't mean much for a cat! It's all about the inner beauty!
But you are totally right, that's why I totally pulled the cat and muffler off. I have a feeling that the cat is clogged and sometimes that crap can make it back to the muffler to clog it too. I'm just gonna start fresh to make sure it's not the area of concern when I try to get this carb all hooked up and running.
