'78 and '79 cross member differences
kmoses
Post by kmoses »
I have a '79 spider 2000 that has the oil pan touching the cross member. The oil pan also has a nasty dent across the front but the cross member shows no sign of any impact. I am thinking the cross member has been replaced, is there a way to tell the difference between the early 1978 and late 1979?
Re: '78 and '79 cross member differences
the later crossmembers have a spacer welded to the surface that mounts to the unibody
kmoses
Post by kmoses »
Thanks Mark!
kmoses
Post by kmoses »
I just checked my '79 for the cross member spacer and there are none. That explains why the oil pan is sitting on the cross member! I my next move is a posting in the "Parts Wanted" section of the fourm. Thanks again for the help.
kmoses
Post by kmoses »
Mark, my '79 spider 2000 has the carb. engine. Does it use the same cross member as the '79 fuel ingected engine?
spider2081
Patron 2024
Patron 2024
Post by spider2081 »
I believe Fuel injection started in the 1980 model year.
RRoller123
Post by RRoller123 »
I believe that '79 was a transition year, with CA cars FI, the balance of the US carbed.
mpollock
Post by mpollock »
I have a '79 California car that's carbureted.
divace73
Post by divace73 »
you'll find that the FI cars started late 79 sometime, no doubt there will be a cross over period
Cheers David
see my >>You tube channel<<
