metal polish
Jazgeek
metal polish
Post by Jazgeek »
took about 20 minutes
200 grit sandpaper then 600 grit sanding then Gord's polish with steel wool
I can imagine what I could do with a couple of hours.... hope it warms up a bit this weekend.
mdrburchette
Re: metal polish
Post by mdrburchette »
Looking good! When you're done with that, you can polish the cam covers and head.
mbouse
Re: metal polish
Post by mbouse »
then, you can stop by my place and show me how to do it. :wink:
Jazgeek
Re: metal polish
Post by Jazgeek »
funnily enough, there's some pretty good "how to" video's on Gord's website.
http://gordsaluminumpolish.com/
ga.spyder
Re: metal polish
Post by ga.spyder »
I bought a bottle of Gords on Jazgeeks referral.It works great and is really easy to use.Heres a pic of my brightwork.
Craig
Craig Nelson
Fling It Around Turns !
mbouse
Re: metal polish
Post by mbouse »
I still don't see the "how to" video that gets Jazgeek to my house to polish my stuff.... where exactly was that again?
Re: metal polish
the dvd comes with the plane tickets you buy for him
Jazgeek
Re: metal polish
Post by Jazgeek »
first class right?
Jazgeek
Re: metal polish
Post by Jazgeek »
hey Ga.Spider... or whoever else may know.
I'm almost bitten.... I think I'd like to try to get to the valve covers and do what you've done... I'm a little afraid though.. how easy is it to take off and put back on the fi cover? If I do take it off and I get the valve covers off, do I have to replace the gaskets under them?
Re: metal polish
unless the gaskets are nearly new, you should replace them
Leesfer
Re: metal polish
Post by Leesfer »
Jazgeek wrote:hey Ga.Spider... or whoever else may know.
I've been wondering the same thing, its been difficult to work around the hoses and whatnot...I want to take the cam covers and fi cover off to sand but is it a simple screw off/screw on?
rlux4
Patron 2022
Patron 2022
Re: metal polish
Post by rlux4 »
Ventura Ace and I just finished doing a valve clearance check on my '82. We were suprised at how easy it was to get the FI stuff off. Just a bunch of hose clamps, nuts and bolts. Be aware though that the two hoses to the plenum on top of the intake valves are water lines, have something handy to plug them off. And the hose going up to the cold start valve may still have fuel pressure on it so watch for spray when you pull it off. Lift that plenum up slowly, you'll find two little vacuum lines under it that you won't see until it starts to come off.
Good luck.
Ron
Ron Luxmore
rlux2n2@gmail.com
