Hey All -
While I was setting up my valve lash, I threw together a small worksheet to try to make the maths easier.
On a couple of flights I did some tinkering with it, added in some other potentially useful stuff. I've also added other models that are near and dear to our hearts. Finally, it supports custom lash too.
https://www.dropbox.com/s/w48kpwkbkmvcw ... .xlsx?dl=0
It may not work directly in your webbrowser if you click on the above link - so download it and run it on your local machine. Sorry - it's in Microsoft Excel only.
If anyone finds this helpful - then job done!
Andy
Fiat Setup Worksheet
- toplessexpat
Re: Fiat Setup Worksheet
Cool!
- aj81spider
Downloaded - thanks!
Wish I had it this past summer when I reset all my shims!
A.J.
2006 Corvette
2006 Corvette
- toplessexpat
You're welcome. It started as a simple assistant when I was thinking about mine - and took on a life of its own!
- Your car is a: 1981 FIAT Spider 2000
Very cool!
Downloaded.
Thanks!
Downloaded.
Thanks!
- divace73
- Your car is a: 1980 Fiat 124 Spider Silver
that's great, what formula do I need to change to have the yellow field in metric?
Cheers David
see my >>You tube channel<<
- toplessexpat
The second row of numbers (in italics) are metric.
If you need to do a metric to imperial conversion, scroll to the right and there's a little table for it.
At some point I'll make an option box to move the whole thing from imperial to metric..... Maybe
