How does this bend?
How does this bend?
I believe the term for it is the pan hard rod... I was looking at my car from the rear and I noticed that the wheels were shifted over to the right side an inch or more, so I got down under it and noticed that this thing was bent and I have no idea how that happened... I did have it at the mechanics and its possible something happened there because I didn't notice anything before I sent it away...
- Curly
- Your car is a: 1968 AC Coupe and a 1976 CS1 Spider
Re: How does this bend?
Not a pretty sight I would hazard a guess that someboy has tried to jack it up with a jack under the diff and it's slipped and ended up under the Panhard rod. It'll need straightening or better still, replacing.
Curly from Oz
124AC coupe http://gallery.italiancarclub.com/124og ... -AC-coupe/
124CS1 spider http://gallery.italiancarclub.com/124og/curly/album52/
from the angle it's bent at, I'd bet it was on a flat bed tow truck at some point and they tied it down from the panhard rod.
Actually it was on a tow truck! Thanks for the insightSo Cal Mark wrote:from the angle it's bent at, I'd bet it was on a flat bed tow truck at some point and they tied it down from the panhard rod.
I"ve seen this quite often. It seems many tow truck drivers may not be the brightest bulb in the box
