race/autocross clutch
We now have 6 puck clutch discs in stock along with a performance pressure plate. The disc is a custom made part with a much beefier hub, steel center piece and springs along with the 6 pucks for increased friction. The pressure plate is remanufactured with a heat treated diaphragm and double straps. This set is designed for autocross or road racing, with over 30% increased friction and clamping power without increasing pedal effort
ClarkTheShark
Re: race/autocross clutch
Post by ClarkTheShark »
I had bought a new spec clutch - I had issues because the pressure plate put too much pressure on my thrust washers and wore them out. Any fear of that here? - or is the force on the thrust washers close to the same when you depress clutch?
ORFORD2004
Post by ORFORD2004 »
What's the price?
These pressure plates have increased clamping power but the pedal effort is the same. The disc/pressure plate set is $395
131
Post by 131 »
ClarkTheShark wrote:I had bought a new spec clutch - I had issues because the pressure plate put too much pressure on my thrust washers and wore them out.
Insufficient freeplay will cause that, or holding the clutch in when stopped for a period of time. I always run plenty of freeplay, a spring on the throwout arm on the gearbox, and gearbox in neutral with foot off the clutch when stopped at the lights.
Mick.
