been reading and see some have found that at one point their trailing arm was used as a jack point .... I am now on that list ..... not if but when it will fail type of dent I have ..... also in my reading.... there is a difference in length of trailing arms around 78 .... can someone confirm that ? and most likely I will save and get all 4 new .... any recommendations??? thanks... Matt
also would like to know if there is an option of new arms that can be rebuilt when needed in the future (bushings)
trailing arm question
- 81SPIDERMATT
Re: trailing arm question
The trailing arms changed in 79. The bushing was changed to a different type. But the lengths stayed the same, and you can use them interchangably. My 79 has a 76 rear end, and the only thing that isn't interchangable is the panhard rod.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
