Yesterday I successfully fixed the horn on the "removal steering wheel'' of my son's Nissan Skyline R32 - so I thought tackling the Spider would be easy. See my other post about that problem !
See Post http://www.fiatspider.com/f08/viewtopic.php?f=6&t=29469
Anyway during the usually lying on your back and fighting with the cables and connectors in confined spaces I was suddenly hit with a shower of sparks as something was shorting. Quickly killed the power to the battery and started to investigate.
I discovered the Service light connector had unscrewed from it's mounting plate (on the right side of the car) and was arcing on the body.
I removed the connector and it contained a light bulb, but I can't see how the light would work ! - all the connector are joined together and were feed by a positive supply (+), the body is plastic and screw base metal and earthed to the body (-), so the bulb couldn't work.
So my most informed friends - what does this connector do ?
Secondly does it act a connector joining other circuits ?
