Tranny arrived late summer and I only had time to open package and see if any major damage as box was pretty badly banged up. So it sat until a week ago. I found a mechanic that has worked on Fiats like this. His father actually had a repair shop specializing in Fiat. Anyway he agreed to swap the two out for me. In the meantime I ordered a gasket and seal set from Auto Ricambi. For 5 speed transmission.
Problems have arisen. I was going to replace gaskets in this replacement transmission but the new front seal looks to be slightly smaller than the one in replacement. On the back where the drive shaft connects there is a small rubber (??seal??) that fits immediately behind the spacer or ?? with the XXXXs. The rubber was in three pieces and pretty mangled. Don't know if I can find a replacement. Also there are 2 plugs, sending units that had 2 wires each (both plugs pretty much destroyed though, wires fell off when I unboxed it. Does anyone know what they are for?? Do I need them for a 1978. I have a replacement for the ruined back up light indicator so that one is OK, just don't know what other 2 are for or if needed. I am now thinking of asking mechanic to use my transmission but replace any worn or missing, broken parts using the replacement transmission. All gears look good to me. I have included photos. Any ideas or advice??
This is on top of transmission.
This is a close up of plug, sending unit on top.
Another plug/sending unit on passenger side of transmisssion.
Close up of unit on side.
Rubber seal was behind the XXX spacer and under the black ring keeping spring in line.
Bolt is on top of transmission, repairable or leave alone if I put this tranny in the car.
Gears in replacement transmission.
Thanks for any advice.
Texsardo
