Heat shield under shifter and center console
joelittel
Post by joelittel »
Does anyone know where to get one of these, or what I could use in it's place? Mine has seen better days and as long as it's out of the car I would like to replace it.
4uall
Re: Heat shield under shifter and center console
Post by 4uall »
joelittel
Post by joelittel »
Thanks for the reply, but it's not that foam piece I'm looking to replace. I'm talking about the one that's stiff on one side, like it's been fiberglassed, and fluffy like fiberglass home insulation on the other. My best guess is that it's a sound deadening and heat shielding material. It does cover the same area of the center console as the one you linked above though.
narfire
Post by narfire »
Years ago I was fortunate to have a boat manufacturing place down the road. When I needed something similar, I went there and ended up with a chunk of sound deadening/insulating material they used around the engine box.
Snoop around and see if there is anything similar in your area?
Chris
wizard124
Post by wizard124 »
Insolite, or similar closed cell foam
joelittel
Post by joelittel »
Thanks guys, I'll look into both those options.
toplessexpat
Post by toplessexpat »
I used the same material i redid the carpet underlay in. Keeps sounds and heat out just fine.
A
www.mirafiori.com
124JOE
Post by 124JOE »
you could go to the scrap yard and pull out some carpet pad from any car and use rubber undercoat on it
then cut to shape
hope this helps.joe
DieselSpider
Post by DieselSpider »
I would just go with industry standard Dynamat whenever possible.
bradartigue
Post by bradartigue »
To make the original material, first catch and then skin 200 cats...
joelittel
Post by joelittel »
these are all great ideas, thanks guys
