Starter motor
PininF
Starter motor
Post by PininF »
Just wondering if anyone has any experience with these new starter motors from Vas as mine's on the way out..:(
http://www.vickauto.com/newstore/index. ... ts_id=4076
RoyBatty
Re: Starter motor
Post by RoyBatty »
FYI,
Chromed surfaces hold heat in a big way. It's usually desireable to allow the heat to dissipate away from our engines and their attached parts.
PininF
Re: Starter motor
Post by PininF »
Ok good advice…So stock standard is better ?
Cheers
John
spider2081
Patron 2024
Patron 2024
Re: Starter motor
Post by spider2081 »
I think the stock starters are pretty good units. If mine starts acting up my first thought would be to have it repaired at a local auto electrical shop that services alternators and starters.
aj81spider
Re: Starter motor
Post by aj81spider »
I got Mark's gear reduction starter (not chromed) and love it. It's much smaller and it starts the car easily. The stock starter is big, heavy, and tough to get in and out of the car.
A.J.
2006 Corvette
spiderrey
Re: Starter motor
Post by spiderrey »
I bought a gear reduction starter motor from Mark also. Cranks engine over faster and lost 10 lbs off my car.
bobplyler
Patron 2022
Patron 2022
Re: Starter motor
Post by bobplyler »
Also, the gear reduction starter is much easier to install.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
bradartigue
Re: Starter motor
Post by bradartigue »
A chromed starter! What a stupid waste of money. Put an ABARTH sticker on it, charge 2x as much, I guess someone will buy it.
Get a gear reduction starter - you can hardly see it, it works great, and draws less current. Otherwise get a stock unit, they're heavy and black, but if you put an ABARTH sticker on it it will be worth 2x.
johnsje6
Re: Starter motor
Post by johnsje6 »
I replaced the stock starter on my '79 with a reduction gear starter from AR - works great and as others have said, less weight and easier to install. (and should be easier to remove if it fails in the future)
John J.
1979 Spider 2000
