Floor insulation?
Floor insulation?
OK, I have started my interior project and I have come across insulation under the center console that is deteriorated quite badly. To replace it, do I use the same material I have seen used on "Overhaulin"? What's the name of that stuff anyways?
Re: Floor insulation?
I got mine here:
http://yourautotrim.com/thercarpad.html
As far as I can tell its a good price. It was easy to work with and seems to be doing it's job with temp and sound.
here are some pictures of my interior with it in there:
- launieg
Dan, how many yards did it take (did you order)? I want to be sure to get enough but not spend a lot more than necessary. Thanks.
Launie
I knew you'd ask me that, so I went scouring through my two year old emails looking for the receipt or something, and I just can't find it. It comes in pretty wide rolls, so I was thinking I didn't have to order more than about 3 yards, but don't quote me on that. I'll double check tonight to see if I have a paper copy of the order.launieg wrote:Dan, how many yards did it take (did you order)? I want to be sure to get enough but not spend a lot more than necessary. Thanks.
I bought the 5 yards of the chepaer padding from from Autotrim, it's also thicker...
You really don't need the reflective stuff for lining the interior of the car except the right passenger side over the catalytic convertor, for this area I lined the bottom with heavy duty aluminum foil (the heavy weight stuff), then the padding, and finally a layer of aluminized mylar (get this at Home Depot or garden stores), then the carpet... it's very quiet now in the car and I reduced all heat from the convertor, plus you save a ton of money over the Dynamat stuff which is only good for the engine compartment.
If you get 5 yards of the padding it gives you extra padding to line the side panels and any exposed metal which would deaden any sounds or vibration... just use spray adhesive and stick the padding in place... works great.
Nick
Nick
- stefhahn
Actually I did use something completely different - cheap, insulation perfect and easy to be installed - I did buy two 12mm isolation mats in black at a local outdoor store - works perfect for more than 15 years now.
ciao,
Stefan
ciao,
Stefan
- Tappy
i ordered moded carpet from this guy http://cgi.ebay.com.au/Quality-Moulded- ... dZViewItem
dunno how it works out but carpet and carpet underlay is about 240 aus $ (225 US$ )
he offer a plusch pile carpet pressed into form , it comes in 2 pieces , very curious how it looks. I have the multiple piece replace carpet and not that trilled about. Its shipped bye sea now from Australia so it will take some time to arrive in europe but when i have it instaled i post some pictures
- Your car is a: 1981 Spider Turbo - missing the turbo
Tappy,
I looked at using one of those carpet kits in my spider as well. However I realised that the sills on the coupe are much thinner than the spider, it should be ok since you'll be cutting the front piece in half to go around the transmission tunnel. It's good quality carpet !
I ended up ordering a seven piece carpet kit from Bruce's ( $265.00USD + Freight ), carpet is a bit on the thin side, only installed it this weekend.
Floor Insulation : I used a Nitrile (rubber) based underlaid which has a heat shield attached and is self adhesive, then I glued another carpet underlaid on top of that to stop the carpet pieces moving around.
Since the car it RHD the drivers seat was getting hot from the exhaust - it's better now !
Regards
Regards
THE FLEET
2014 Abarth "SS"
2014 Abarth "SS"
My order arrived yesterday. Looks like a good product, and it appears very close in thickness to the original material. Thanks for the tip and linkDanno wrote:I got mine here:
